Just need verification that the psu is defective or I'm just way off on power usage. These parts are all brand new, less than a week old.
Here are my build specs:
CPU: Intel Core i5 3570K
Mobo: Gigabyte Z68X-UD3H-B3
Video Card: ATI Radeon HD 7870
RAM: G.Skills Ares 32GB (4x 8GB) DDR3 1600
SSD 3: 120 gig SATA 6.0
HDD: 3 TB 7,200 RPM SATA 6.0
Optical: DVD-RW
POWER: Corsair TX750 V2
Windows 7 Ultimate OS.
My problem is with all 32gig installed, the comp loads very slow and while in windows stutters and freezes or even crashes if i perform more than 2 actions at the same time. However when I drop it down to 16 gig, everything works fine. I've swapped the ram into different channels, checked the mobo, checked all the other hardware. It only occurs when all 4 sticks are in simultaneously. All the power checking calculators say I should be fine at 500 or 600W, and yet I run into the instability with the ram. Is the 750 not enough? I've yet to OC anything yet, they are all running at normal settings. Could something else be the culprit?
Optical: DVD-RW
