75hz monitor compatible?
Tiago4151
Commendable
Dec 10, 2016
5
if I have a 75h monitor but play games at 90-110 fps will I get screen tearing?
And if I enable v-sync will it disappear?
Lastly that monitor has free sync but i have a gtx card fom nvidia so I can't take advantage of that right???
thanks
Which GTX card do you have? NVIDIA pascal GPU's have fast sync, which is compatible with ALL monitors. It works like v sync except it doesn't limit your frames, it gets rid of screen tearing, and has very little input lag.
I have a gtx 1060 6gb and i think that all of the 10 series have the pascal technology :)
I didn't know about that feature thank you 😀
No worries, I was glad to find out about this feature when I was getting my 1060 3gb XD
If you are still there can you tell me if this monitor is good for gaming? http://www.chiptec.net/perifericos-externos/monitor/monitores/benq-led-gl2250hm-fullhd-hdmi-2ms.html?
the site is portuguese but i think it's easy to understand : )
I can't see the refresh rate, but it seems like a good monitor.
I use https://www.amazon.co.uk/dp/B016AWBVXQ/?tag=pcp0f-21
and it seems to be similar to yours.
