P papabanter Prominent Dec 26, 2017 5 0 510 Apr 21, 2018 #1 I recently bought a 75hz monitor and i noticed that it displaying 60fps. I've went into the nvidia control panel and looked if i could change the refresh rate from there but i can't it's stuck at 60fps also i'm using a hdmi cable
Solution Glenwing Apr 21, 2018 papabanter : Greeko85 : Whats your monitor's model? my monitor is an AOC G2260VWQ6 That monitor may only support 75 Hz over DisplayPort. Some monitors are limited to 60 Hz over HDMI.
Glenwing Splendid Aug 8, 2015 3,206 349 25,990 Apr 21, 2018 #2 Make sure you are selecting the resolution from the "pc" section of the list. Upvote 0 Downvote
Greeko85 Honorable Oct 3, 2015 2,120 7 13,165 Apr 21, 2018 #3 Whats your monitor's model? Upvote 0 Downvote
P papabanter Prominent Dec 26, 2017 5 0 510 Apr 21, 2018 #4 Glenwing : Make sure you are selecting the resolution from the "pc" section of the list. i went on pc and it only had 1680x1050 and it only had the option of 60hz Upvote 0 Downvote
P papabanter Prominent Dec 26, 2017 5 0 510 Apr 21, 2018 #5 Greeko85 : Whats your monitor's model? my monitor is an AOC G2260VWQ6 Upvote 0 Downvote
Glenwing Splendid Aug 8, 2015 3,206 349 25,990 Apr 21, 2018 Solution #6 papabanter : Greeko85 : Whats your monitor's model? my monitor is an AOC G2260VWQ6 That monitor may only support 75 Hz over DisplayPort. Some monitors are limited to 60 Hz over HDMI. Upvote 0 Downvote Solution
P papabanter Prominent Dec 26, 2017 5 0 510 Apr 21, 2018 #7 Glenwing : papabanter : Greeko85 : Whats your monitor's model? my monitor is an AOC G2260VWQ6 That monitor may only support 75 Hz over DisplayPort. Some monitors are limited to 60 Hz over HDMI. thanks Upvote 0 Downvote
