760gtx gigabyte ovoltage problem
Executor77
11
Hi I have 760gtx oc windforce rev1 card. Wanted to push it even more but i cannot overvoltage it. Is this card voltage locked?
Iam using msi ab latest beta with modified .cfg supporting unofficial oc. Problem is i can add 12 mV but gpu z shows no change. 1.2V is max on load. Am I missing something or nothing can be done?
All gpu's are voltage locked, and can have that 12mv added, which is what takes the gpu voltage up to 1.2. you need a modded bios (if you kill it with a modded bios you will not get a new one). nothing you can do without modding the bios. buy a faster card or a second one if you want more performance
