770 twin frozr heat/fan questions.
Tractortaylor
7
Just got done building a new PC. However I am experiencing some higher temps with my graphics card around 70-75C. In my older build that same gtx 770 twin frozr ran around 40C. I did get a new mobo and processor so im not sure whats going on. I have 2 pushing air from the front and one pulling from the back. I'm looking at getting another couple fans to push from the side and from the bottom. What do yall think? is that normal temp range? See comp stats below!
Pcu - fx8350
Gpu - Geforce gtx 770 twin frozr
Psu - Corsair Cx750M
Case - R4 Fractal pearl case
Fans - x3 Fractal 140mm
Mobo - Sabertooth fx990fx
Pcu - fx8350
This temperature is normal for this GPU, you have nothing to worry about, just make sure it does not exceed 80c.
Edit: Sometimes a new motherboard, just won't support the OEM fan curve so the fan stays at 20-30% RPM all the of the time... if you are really worried you can do a custom fan curve using MSI afterburner. But as I said before 70-75c is a normal temperature.
