770 waterblock help
Danielmulv
11
I bought this a while back from eBay and he said it was a gtx 770 water block but it didn't fit on my 770 Mao twin frozr but I found out there isn't one for the so I'm wondering if someone can help me and tell me what gpu it is for and what one to buy
http://postimg.org/image/5f7ozvxw9/
5f7ozvxw9
Danielmulv
11
[quotemsg=16970542,0,690511]It very well could be a water block for a 770, but since your card is not a reference card it does not fit. without seeing or knowing the make of the block its hard to tell what it will fit.[/quotemsg]
im trying to upload an image so that someone can tell me exactly what one its for
Danielmulv
11
[quotemsg=16970547,0,2104758]Then you will want to buy a reference GTX 770.[/quotemsg]
But i dont know if the waterblock is for a 770 thats why i need someone to check
[quotemsg=16970599,0,2104758]http://www.xs-pc.com/waterblocks-gpu/razor-gtx-770[/quotemsg]
[strike]Nope the block he has is this http://www.xs-pc.com/waterblocks-gpu/razor-gtx-titan-780-780ti For a titan, 780, or 780Ti
Look at the lower left corner of the block the indent is bigger on his picture then what the 770 shows. It matches the 780 block.[/strike]
Spoke to soon..... still trying to figure it out. It doenst have the 770 stamped after the GTX and the screw under the XSPC does not match the 770 as well. His screw is under the S while the 770 is under the leg of the P.
