7700k CRYORIG C7 CPU Cooler
culzone
555
CRYORIG C7 CPU Cooler can this cooler handle my 7700k?
I've got a 7700k in my current build and I want to make it a LAN build with the raven silverstone rvz02.
im running it 1.2v 4.5ghz with my nzxt x61 watercooler hits 65C during realbench. (not 100% fan speed)
But in order to use the silverstone case I need something like the CRYORIG C7 CPU Cooler but will it handle the temps?
might go 1.1v 4.2ghz then 😛 or something like that
the cpu is also delidded
is there any other cooler you can recommend that fits the silverstone rvz02?
Oh god the Rvz02... that thing is a pain in the ass for cooling. It has a pretty big following tho so you might be better off with checking out forums dedicated to it. From the limited stuff I've read on it, the thing was just not designed for anything other than basic low profile cooling. So the problem isn't so much finding a cooler, its finding a cooler that can compete with any real OCing attempt. You might want to consider the Rvz01, which was designed to allow for a single rad water AIO.
Just tried 4.2ghz, 1,1v during realbench with an older stock cooler and maxed out 82c compared to the nzxt x61 at 65C maybe the AIO was not properly mounted but watever. Im guessing the C7 could be about 5-7C better than the stock cooler?
EDIT: AIO cooler ran 25% fan speed only so that was why I guess
