Question 7700k delid and relid
teeshq
24
So the day just came i have der8auer Delid-Die-Mate 2 and thermal grizzly conductonaut have plan to dont put silicone again to secure IHS on pcb but need think about put on corners b7000 glue (just to instal into mobo then cpu clamp will secure ihs) . How you think will this work ?
I am having a similar question and concern up in the air, got 0 feedback so far... Not yet sure what to do. The die is touchy and if it gets damaged - it is gone. While it should work short term with no issues, on 2nd and 3rd application anything harder than gasket maker may do damage while getting the lid off again. Not having anything may do damage if it moves... Also having warranty is a nice-to-have.
P.S. what is your temperature delta between the CPU and the heatsink? (if you have a thermal sensor on it)
