R rony1998 Honorable Nov 23, 2013 11 0 10,510 Nov 23, 2013 #1 want to buy a 7750 but i have G4md motherboard and odeesy 450 watt psu and pci-e x16 1.1 slot. Can it be run???? plz answer need help !!!
a1blaster Honorable Sep 14, 2013 572 0 11,060 Nov 23, 2013 Solution #2 it will run but you have to update your mobo's bios.... Upvote 0 Downvote Solution
R rony1998 Honorable Nov 23, 2013 11 0 10,510 Nov 23, 2013 #3 a1blaster : it will run but you have to update your mobo's bios.... how to update??? Upvote 0 Downvote
Simu Honorable Nov 28, 2012 191 0 10,710 Nov 23, 2013 #4 yup you can install and use with your current psu. Upvote 0 Downvote
R rony1998 Honorable Nov 23, 2013 11 0 10,510 Nov 23, 2013 #5 Simu : yup you can install and use with your current psu. 100 % guarantee?? 😛 Upvote 0 Downvote
R rony1998 Honorable Nov 23, 2013 11 0 10,510 Nov 23, 2013 #6 Simu : yup you can install and use with your current psu. can 650 handle that??? Upvote 0 Downvote
Simu Honorable Nov 28, 2012 191 0 10,710 Nov 27, 2013 #7 rony1998 : Simu : yup you can install and use with your current psu. can 650 handle that??? what is 650? dude... Upvote 0 Downvote
R rony1998 Honorable Nov 23, 2013 11 0 10,510 Nov 28, 2013 #8 Simu : rony1998 : Simu : yup you can install and use with your current psu. can 650 handle that??? what is 650? dude... gtx 650 Upvote 0 Downvote
Simu Honorable Nov 28, 2012 191 0 10,710 Nov 28, 2013 #9 rony1998 : Simu : rony1998 : Simu : yup you can install and use with your current psu. can 650 handle that??? what is 650? dude... gtx 650 ya it should work fine but if u can spend some more bucks get a decent psu like corsair cx 430. Upvote 0 Downvote
R rony1998 Honorable Nov 23, 2013 11 0 10,510 Nov 29, 2013 #10 Simu : rony1998 : Simu : rony1998 : Simu : yup you can install and use with your current psu. can 650 handle that??? what is 650? dude... without any external psu can i run???? also have odyseey 450w gtx 650 ya it should work fine but if u can spend some more bucks get a decent psu like corsair cx 430. Upvote 0 Downvote
MikeEOD Honorable Aug 10, 2013 42 0 10,540 Nov 29, 2013 #11 rony1998 : want to buy a 7750 but i have G4md motherboard and odeesy 450 watt psu and pci-e x16 1.1 slot. Can it be run???? plz answer need help !!! I had a 450w PSU on my 7750 and it was fine. Upvote 0 Downvote
