Question 7900XTX in 4000D with Front AIO?
zmihlrad
160
Never really considered it but should I have concerns about fitting a 7900XTX into a 4000D? Don’t really want to have the bigger case or spend the money but the 5000D worst case is on sale.
i know there is limited info on AIB options to come but I will likely save the money and go with a founders edition.
i have a Corsair AIO with cooler and fans inside the case so it looses around 2”.
360mm max. Fans are 25mm thick.
If radiator is 38mm thick = 297mm
If rad is 30mm thick = 305mm
If 27mm thick = 307mm
You've probably figured it out at this point.
well… they claim the 7900 founders is 287mm. So we’re cutting it realllllll close. But it would make it…
i suppose if need be i move the fans to the front and leave there radiator there i gain an inch.
