7970CF Low Usage, Low FPS.
wadawada55
113
So, i used to own 2 6970's which used to run bf3 fine, but had to give them away to a friend.
So i decided to buy 2 Gigabyte 7970's thinking these would last me a few years.
ran Bf3 for a few days running perfectly over 100FPS, but now cant seem to get more than 60 unless scoped in with sniper. I ran MSI afterburner to check if CF was working properly, which it was but cards were running from 55-70% which i'm wondering if that is the issue? Running metro 2033 runs superb, averaging the performance it should be and running at 90%+usage..
Boarderlands two seems to be having the same issue as BF3.. The campaign on the other hand runs 90%+ like it should also.
Specs:
Asus Rampage Extreme III
i7 960 3.2Ghz
12gb G.skill Sniper 1600hz Ram
2x Gigabyte 7970 GV-R7970OC-3GB
TX-850
Corsair GT 120gb
12.11 Beta Drivers (I've tried others, with no change)
Samsung S27A750 120Hz
Reformatted to Windows8 hoping for Better performance but Nothing. (Reason for the two cards on 1 screen, is to get the 120fps+ on gaming to look nice at 120hz..)
Did you change drivers recently? I don't cf, but with my 7870 I have trouble in a lot of games with 12.10 or 12.11. I have to use 12.8. How hot are the cards getting? Also, what is the cpu usage like in game? If it is 100% that's your problem.
That wouldn't make sense since the OP stated that BF3 initially ran at 100+FPS with his setup, and only after a while ran slower.
I highly doubt this is the problem but make sure you don't have any custom profiles set for those games in CCC under the Gaming section. And make sure that there isn't a custom global profile set (Although that's very unlikely since you said Metro is running fine).
Ive tried ocing CPU up to 4ghz but that didnt make a difference,
Usage of CPU sitting around 65% never going over 85%,
When in intense situations the GPU usage goes down rather than up, along with the FPS.
Ive tried with HT off and on, off made it perform worse.
Cards are running no more than 70Degrees.
And no CCC profiles have been ever created, all is set to "use application settings"
i always turn VSync off also, hate the Delay from the monitor to the mouse.
Look man, I gave my 2 cents. to say i'm wrong is one thing. but to say i'm wrong then use my point as your own is taking credit in my book.
I am about 99% sure this is a driver issue, since BF3 works well with cf. Try 12.6, 12.8, 12.10, 12.11b4. Use driver sweeper between each install to make sure you completely remove one before trying the next. Start at the newest and work your way back. You said your cpu usage is 65-85% so that is a nonissue. You said your temperature is at 70C, which is good.
Okay, i will try this step next, Once i get home from work.
i'll reply in about 8hrs.
Okay so tried a few drivers, yeilding best results from RC11 drivers but was causing micro stuterring. after was 12.8, which was stable and gave about 5% increase in usage and FPS
http://i.imgur.com/PQJze.png
ive added a pic of usage, the high spikes are when i zoom in with scopes, which when i zoom in seems to make the usage go up to about 95% and giving 150frames.. I dunno whats going on..
Its a bit better, about 5% improvement on 12.8. The usage always went way up along with my frames when i zoomed in with a scope 4x or more.. not sure why when the Usage should go down as its not displaying as much on the screen.
yea... I have no idea whats going on..
Considering RMA'ing both cards..
singles they run properly, but only giving like 60frams..
I have two 7970's as well and the same drivers and I don't have any issues with Battlefield 3. I am not sure what is going on, but just wanted to put that in there for you.
Thanks beethree, have you tried those cards on a system with Worse CPU? or stock clocked CPU?
I just tried running crysis2, usage is 95% when nothing going on avergaing 120fps, then once action usage drops to 50% and FPS hits 50fps.
tried it with the un-installation of MY xonar STX drivers, thinking the driver might be colliding but that didnt work, another upload of levels.
http://i.imgur.com/z13bu.png
just noticed that 1 card is a bit different so may be a generation of the same card but a bit older, could this be an issue? 1 my have a newer bios or something?
thanks for ur support guys.
Did the problem start happening after you installed afterburner? How were you measuring FPS prior to using afterburner? Reason I ask is because afterburner could be conflicting with the catalyst control center. Since you have afterburner installed, I'd recommend going into the performance tab of the catalyst control center, click on overdrive then uncheck Enable Graphics overdrive and also make sure manual fan control is unchecked...do this for both cards (you can change cards at the top of the screen). After doing this, go into afterburner settings, and check the unlock voltage control (might need to use kernal mode to do this)...apply that, it will want to restart the program. Once afterburner is running again, change the power limit to atleast +10% (I run at +20). You can mess around with overclocking the GPUs if you want, but do that after you fix the GPU usage issue. Also, make sure that the synchornize settings for similar GPUs is checked. To ensure that both cards are clocked to the same level, look at the clock levels of the first card in afterburner...then go into settings and change to the second card, and then look at the clock levels in afterburner to make sure they are the same.
As for the BIOS, I wouldn't bother going that far just yet...both cards should work just fine together as long as they are clocked to the same level.
now that i think about it.. it was around the same time, before i just used to use fraps, or in game settings if they had them. thanks for the advice i will try all those things and get back to you! :)
Okay, tried this. i just tried un-installing MSI afterburner, and just using in game FPS settings on BF3 with No result.. and boarderlands just used fraps.
i do know that the bios is different from what im seeing on the info, 1 card is 5 months newer.
If it's the same style of card, you could save a copy of the newer bios and flash the other card. I can explain that better tomorrow, or you can google it. Another quick thing to try prior to flashing the bios...disable ulps on both cards, I'm exhausted but it is easy to find on google. Also there is a newer beta 12.11 that you can try. Not sure if there is a new CAPS
Have you used GPU-Z to check that both cards are running at the same clock and memory speeds? I'm wondering if one is a GHz edition and the other is a standard edition since they have different bios.
It still confuses me that your GPU usage drops to 50% I ran BF3 and BL2 for about 10 minutes each and then checked afterburner, my cards stay at around 95-100% usage except during loading screens....FPS always stays above 100 in both games, most of the time stays above 200 in BL2. My setup is a I-7 3930k @ 4.4GHz, Asus rampage extreme IV mobo, ocz agility 4 ssd in raid 0, XFX 7970 DD CF 1100 MHz clock and 1500 MHz memory.
