kikobie Honorable Sep 2, 2013 97 0 10,630 Oct 29, 2018 #1 as the title says can you suggest one or are there only 8th gen compatible motherboards that have this feature? I have an Intel 7700k by the way. TIA
feelinfroggy777 Glorious Dec 13, 2016 5,722 135 45,990 Nov 2, 2018 #2 Most of the higher end mobos will have the RGB header. The Gigabyte Z270 Gaming 7 has it. https://www.gigabyte.com/Motherboard/GA-Z270X-Gaming-7-rev-10#kf Upvote 0 Downvote
kikobie Honorable Sep 2, 2013 97 0 10,630 Nov 2, 2018 #3 feelinfroggy777 : Most of the higher end mobos will have the RGB header. The Gigabyte Z270 Gaming 7 has it. https://www.gigabyte.com/Motherboard/GA-Z270X-Gaming-7-rev-10#kf Is it adressable RGB? Upvote 0 Downvote
