Question 8 Corsair 120ML with hub for 6 fans. [SOLVED]
Sep 21, 2019
9
Hi
I’m bulding a pc on a Corsair 570x, and I’m planning to use Corsair H100i (which comes with 2 fans ML120).
I will install it it as push/pull in front of the case, where it will have another 3 ML120 (I will replace the stock fans). Then I will put two ML120 on the top and one on the back.
so I will have 6 ML120 in the case + 2 ML120 from the H100i.
I will connect the 6 fans of the case to the “Corsair fan Hub”(don’t know the proper name of this) with the “node pro”, and the H100i fans to the motherboard. If I do this, will I be able to control all fans with iCue?
Thanks in advance and I apologize if I’m not being too clear with what I want do to.
Latest posts
