8 led PC fans
Mool123
Commendable
Jul 4, 2016
I'm building a Pc for the first time and I plan on gaming on it and installing 8 led fans what motherboard would be able to support that amount or should I just get fan splitters
5 120mm led fans
3 140mm led fans
Get four 4 pin fan splitters and you are good, they are quite cheap, around $1.20 AUD each. I also bought 3 noctua ones for $1 on clearance 😀
MERGED QUESTION
Question from Mool123 : "I'm building a Pc for the first time and I plan on gaming on it and installing 8 led fans what motherboard would be able to s"
What are your parts?
Are you building a gaming PC or a neon windmill?
Even the hottest parts can be cooled with two 120mm intake fans and a 120mm exhaust.
8 fans seems like overkill.
It will add noise and expense to your build.
Save the $ and use it on performance parts.
If you want led's, they do not consume much power either in a fan or stand alone.
