8 Months of Banding Issues... Have Tried EVERYTHING. Could Use Help
SkippyMcGee
54
For the last 8 months I've been having what started off as general Color Banding, and has turned into I don't even know what now.
Firstly, though I have had and have absolutely 0 performance or stability issues with this rig. Everything runs fast, everything runs smooth, temps are stellar on both GPU and the CPU. This computer runs like a dream in that regard. Which is good and bad. Good because the well, a fast stable rig is good, bad though because it doesn't help me pinpoint the problem which is omnipresent.
To start off, I've attached some jpg images of the problem. It's not related to just one game, I can find the issue in every game I'll play. I can even see banding on this forums background, it's not severe due to the backgrounds light colors but it's there. In the screenshots it might be hard to see if you have your monitor really dark though. Also you should make the picture fullscreen, 1920x1080.
Also possible related, is streamed videos lately appear somewhat grainy/pixelated, not all, but some. And they seam be constantly refreshing every .25 seconds. You have to really look to see it. Like even a stable background of stream, you'll see it constantly sync into place as is the best I can describe it. Like it will be clear, then .25 seconds it will refresh grainy to clear. Just general streamed video crappiness, that wasn't there 8 months ago. Also you know that default Windows 7 HD video that is installed of the horse running, ya that looks like shit and definitely not HD.
Anyhoo, this problem originate when my old monitor apparently out of the blue died. The left side went darkish/purple. I confirmed it was the monitor by hooking it up a different computer.
When a new monitor(same make/model) was sent to me, as I was checking it for dead pixels and general problems I noticed some color banding on gradients. I was then shipped another monitor, which produced the same results and then finally another one, again with the same results. I then hooked up an older known working monitor, which also produced this problem.
I then tried different input cables, HDMI/DVI/VGA, all produced the same results. I tried different cables for each input as well, same results.
Then I tried 4 different Nvidia drivers, clean installing each. Using known working versions I had previously used. All produced the same problems. I swept each of them after each install, everything was installed clean.
At this point I tried everything that I possibly could figure to be related, in both the Nvidia control panel options and the Windows Color Management options. Through here, I could "minimize" the problem, but it was still there, I was just bandaiding it by ****ing up colors to try bare though it. And yes the first thing I made sure of was that I was in 32bit Truecolor mode on both the GPU and Windows.
Obviously I vigorously checked for malware/viruses/whatever. Also my chdsk and countless other things as well.
My next step was contacting my GPU manufacturer as this was the most logical solution. I was sent out another GPU same make/model, at the time this was a (EVGA GTX 670FTW 2gb). The new GPU produced the same result. EVGA was nice enough to send me out yet another card just rule out, a strange coincidence that 2 cards were producing the same problem. The 3rd card produced the same result.
Here I was kinda losing it and getting frustrated. My next logical step was reinstalled Windows, a full clean install, nothing remained from the previous version including my data/etc. Knew it didn't work just by the Windows Screen I could see minor banding from when you get to the Ctrl-Alt-Del background of Windows.
And now completely losing it, and after some help from various companies and what not we tried a different PSU. It was an off shot, but was "possible". The new PSU, produced the same results.
Having very few options left, EVGA and a few other said it was "possible" it could be my Mobo. Either a faulty PCI slot or various other things. Here I was hesitant but I tried everything else. And let me add, ASRock has absolutely non-existant customer support. Anyhoo, I had to buy another mobo, and due to me trying to rule out conflicts, I purchased the same make/model. I was planning on reinstalling Windows again just rule out any odd issues that arose. The new mobo worked without a Windows reinstall, but the banding issue still persisted. So I again reinstalled Windows, completely clean yet again, the issue was still there.
At this junction, I once again tested my RAM(I had previously done this, but forgot to mention it earlier), both through memtest and then just trying each stick in different slots to see if any would lessen/increase the banding issues. I tried each stick seperate and in different slots. Every combination produced the same banding.
One last Hail Mary, and again EVGA is absolutely fantastic, I was sent another GPU this time a different model an EVGA GTX 770SC. Because in reality, the issue thought by me and almost everyone else I talked too, made it seem like it HAD to be the GPU. Well finally got the new GPU and take a guess, yep, the banding is present.
So here I am... 8 months ago and prior to that for 1 year, I had absolutely 0 issues like this or anything even remotely related.
It all began with a monitor dying, or at least the monitor dying made me look for the problem. It is possible it was there prior or began slightly prior.
Every single thing in this Rig has been swapped out, except the CPU and SSD. I would have swapped those out, but was told from dozens of people, that the issue I'm having could not be related to those 2 components. And in all honesty, I don't think it could have been related to a few other parts I'd already swapped out.
So ya... Oh, and before I forget here's a list of some other oddball things I personally checked to try to rule out the problem.
-Tried different Electrical Outlets, surge protectors, power cables ruling out some bad juice from my house. Tried 4 different rooms.
-Moved everything and anything that could possibly cause some sort of magnetic interference.
-Took out my wireless card, disabled the wireless in the house, ruling out some other sort of interference.
-Tried random mouse/keyboards/usb devices thinking maybe something could interfere as well.
-Obviously checked all chipset drivers other stuff.
-Updated Mobo's BIOS.
-Checked various BIOS settings. Even though everything in my Rig is Stock no OC'ing or anything.
-Swapped most if not all the cables in my rig. Basically every modular cable not attached to a part. Even the non-modular cables were swapped when like I said before I swapped out basically every part in my rig.
There's probably 100 more things I've tried that I can't think of right now, over the course of the last 8 months.
I'm just looking for some help here. What I think and I'm probably wrong though, is there is something in Windows that is causing this, some setting or something.
The problem is most pronounced on alot of game's "vignetting" and in smoky/hazy effects/areas, the screenshots I included should show you. Also light sources seem to produce the banding around them, glowy effects you'll see the pulsing banding.
Alot of website background gradients you can see it, I know some are due to the compression of the imagine, but some aren't. Steam's Client will band, if anyone is familiar. The Windows Aero Glass effect will band with a solid black ground and transparency set.
What's kinda funny though is a game like FTL with it's retro design, doesn't appear to band even on their gradient changes.
I think my current specs are listed on this site's information I just updated them.
Also someone at Blizzard looked through my msinfo and dxdiag and didn't see anything that could cause the issue of the pictures I sent them. They assumed it was the GPU/Drivers, obviously.
I personally don't know what to do next. Short of building a brand new rig, with completely brand new unrelated parts. I can't fix this problem. And I'm too broke to even consider that option.
If anyone, has any suggestion, and I mean anything... That would greatly appreciated. I have no clue what is going on, I've tried everything, and I'm at the point where I dread using this computer that I used to spend so much time on, because the constant in my face taunting of this banding issue everywhere I look.
Sorry for that long rant. Here you can see a sample of the issue in the game Diablo 3. It's in every game, dark/hazy games most notably. Any game with "vignetting" even bright games you can see it if you really look in the corners as well.
What's strange is everything in the center of the screen is crystal clear and crisp. This is true for nearly every game, except DayZ-SA in nighttime maps. In that game at night everything is washed out and banding at night. During the daytime you can see vignetting at the corners but at night everything is banding together and washed out grays/blacks.
Windows 7 Home Premium
i5-3570k
AsRock Z77 Extreme4
EVGA Nvidia GeForce GTX 770SC
2x4GB Crucial Ballistics RAM
HP Pavilion 23xi IPS LED
1920x1080 @60hz
Crucial 256gb SSD M4 2.5 SATA6GB
Thermaltake 850w Smart Series 80+B
CoolserMaster HAF 912
CoolerMaster Hyper 212 Evo
1st Picture: You'll see the banding around the game's light source around the character and the game's vignetting. The oval camera like design around the center of the screen.
EDIT: This first picture when I open it up from this site after uploading it, the banding is there but rather minimal(compared to what I'm used to), when I open this picture up on computer with Paint/Windows Media/whatever, the banding is EXTREMELY pronounced. I don't know what this means, or if it's a good sign, or means nothing. If I save the image to my computer the banding comes back just like the original, but if it's opened through this forum it's minimized. Coincidence???
2nd Picture: This just seems like something's f'd up, over the bridge to the right of the character, the hazy area just bands in weird directions.
3rd Picture: To the left top left, the gray hazy area, just seems off. It has banding but in no direction it seems to cross itself and stuff doesn't seem clear in the smoke.
4th Picture: General Vignette banding, most notable towards corners of the screen as it gets darker.
313312d1397092542-8-months-banding-issues-have-tried-everything-could-use-help-screenshot001.jpg
313313d1397092542-8-months-banding-issues-have-tried-everything-could-use-help-screenshot003.jpg
313314d1397092542-8-months-banding-issues-have-tried-everything-could-use-help-screenshot004.jpg
313315d1397092542-8-months-banding-issues-have-tried-everything-could-use-help-screenshot000.jpg
Have you really not considered the possibility that the model of monitor you were using inherently is grainy with a 6-bit panel and poor viewing angle? You may have gone through all this trouble for absolutely no reason.
What model of monitor was it, anyway?
You typed quite a bit there. I didn't have time to read through every detail but to me all of the computers that I have seen with any type of banding issue comes from a video card related issue. Normally just a simple swap can fix the issue. You can't fix it with drivers bios or anything else really.
I think I wrote that I tried multiple monitors, if not sorry, I wrote alot. Also the monitor I was/am using, the make/model had worked fine for a year without any banding issues anywhere.
I didn't list my computer specs sorry, just noticed and updated.
The monitor is: http://www.newegg.com/Product/Product.aspx?Item=N82E16824176424
HP Pavilion 23xi Silver / Black 23" 7ms HDMI Widescreen LED Backlight LCD Monitor, IPS Panel 250 cd/m2 10,000,000:1
The original had worked flawlessly til it died. The subsequent ones I was sent, as I tested them for dead pixels/calibration is when I first noticed the banding and all subsequent monitors I was sent produced the same result.
I even tried 2 older monitors I had used on different rigs which I know for a fact work perfectly and these monitors produced the same results.
Kinda wish you read through everything :)
4 Different GPU's in total have been tested with all producing the same exact result.
Original EVGA GTX 670FTW 2gb
2 more EVGA GTX 670FTW 2gb
And finally a EVGA GTX 770SC 2gb
All produced same results.
Hopefully you can read through all I typed, I know it's alot. But hopefully you can find something I didn't try, I'm looking for anything, because I think I have tried everything.
I had that thought was well, and the PSU was replaced. At first with a RMA's exact same make/model. It produced the same result.
I was then sent an "upgraded" version, and it too produced the same result.
3 PSU's in total produced the same result.
The original PSU was in fact tested and found to have no issues, both by the manufacturer and by me personally. Stable +12v and within norms and providing the listed and adequate power.
The original mobo yes, I did that a few times while trying to reseat the original GPU thinking that was a possible cause. I tried both PCI-E slots as well.
Actually did that multiple times since I was sent multiple GPUs.
The new mobo I did as well, as well as trying both PCI-E slots in that one too. Actually twice on that one as well, since I was sent the 770 after replacing my mobo.
The CPU and the SSD are the only 2 components that haven't been swapped out.
I would have tried swapping them out, but was told and adamantly so by multiple people that these could not possibly be the cause, especially without lack of any other related issues.
I have tested the CPU with prime95 and I have checked for corruption on my SSD. All have and seem to be working properly.
You know how when you talk to someone at one manufacturer they at first try to point you to another manufacturer, say the GPU people will try to point you to the PSU people and so forth.
Well none of these people even when asked about these 2 components said that these 2 parts could be the cause, which kinda reinforced that.
I only have seen a handful of processors go bad. But I think that would almost be the only culprit. I once tried everything I could think of for that issue but then the fix was something with the processor not communicating correctly. So the quick fix was to buy the cheapest processor that I could find for that socket and then seeing if it worked. Which it did. So after that I returned the cheapo processor and bought a good processor knowing that it was the fix
I was willing, reluctantly though, to swap out my CPU about 6 months ago thinking it "possibly" could be the issue. I was convinced otherwise because it made more sense, so I went a different route which actually ended up being every route lol.
Problem is now, the CPU obviously not under warranty anymore. I did talk them on the phone awhile back when it was, because well I have talked to everyone sadly. They were unwilling to RMA me a chip, since as they said, this problem couldn't be caused by the processor directly. And since I had no other issues with the computer to make them believe it could be related to another issue with the CPU(I mean I could have lied, but lying doesn't help anyone solve a problem), there was nothing more they could do besides general tech advice.
Also I'm assuming you read my whole original post now, so I guess you could figure how much cash I've dropped on this issue already.
So while I will agree it is "possible" and I mean every so slightly possible despite 99% of the people I've talked to saying it isn't. I can't really justify buying a new CPU to test it out, especially with the extremely restrictive return policy with Processors/Mobos at pretty much every place I've ever purchased hardware from.
I would need alot more reassurance before going that route, and I mean alot more. Like I couldn't find a single thing on the entire internet about relating an issue similar to mine and the CPU. Nor could I find a person or an acquaintance of a person who has heard about a CPU causing color banding(or w/e my issue is called).
And honestly if I have to replace this CPU, I'm gonna take this entire rig and throw it out my window and then run over it with my car out of pure hatred. And then just build a new one with parts that don't even share the same name as anything in this current rig... Granted that won't be for some time, because I can't afford it lol.
Did you try underclocking your processor a little bit? I know overclocking can cause that issue but maybe trying something like disabling turbo boost and reducing the clock speed and voltage a bit. I think that is about the only thing that you have left to try other than trying to swap it out of something like a $40 celeron.
Everything is stock in my rig. Only reason I ended up with the 3570k instead of 3570 was cause it was actually 30 bucks cheaper at the time for some reason.
I have messed around in my BIOS settings, not much but a little. Reason being, the only thing that I ever touched when build it was the case fan speeds. Meaning nothing in the BIOS has changed before the problem started to after the problem starting.
I could look around there a little more I guess.
Only issue is, while this problem is annoying and everlasting. I can't afford to actually do something to this rig that will put it out of commission permanently, it's gonna be a little bit before I can realistically replace it dollar wise.
Also I'm not exactly all that familiar with most BIOS options besides common sense stuff, so fucking around in there, seems rather futile.
I have checked basic stuff in there though and everything looks normal, besides that everything besides the fan speeds are default. And have been default on the original mobo and this new one. I don't think anything in there caused this issue to start.
The thing that is personally got me confused right now is that first picture I attached. For some reason that picture when viewed on this forum through Firefox or whatever renders it, the banding is minimized it's there but not "horrible". Yet that same picture whether the original or if I save if off the forum, the banding is intense and very noticable, just like if I was in game.
Is there something different when viewing that picture than when viewing that picture on my computer? Does Firefox do something different than when I open that picture with Paint/Windows Media Player or whatever?
It really makes me think it's something Windows related, I don't know why.
The only other thing that I could think of is try seeking out a repair shop in your area and see if they have another processor that would fit that socket. My friend did that only for a power supply related issue but they had lots of extra stuff lying around. He called them and asked if he could bring in his system to try a different power supply and they did it for free. So as long as it isn't some big place like geek squad they should be nice enough to let you try it,
Sadly out of desperation I did take it to a "repair shop" about 3 months ago...
So I called around my area, most of these places are dudes just trying to make a quick buck off of some older person, housewife, college kid, who got some malware from opening some phishing email or porn or whatever stupid link they clicked. These guys make a living off other people's lack of common sense.
Anyhoo I talked to about 10 different places, telling them my issue asking them basic questions. I mean only one of them knew what color banding was, every single one of them told me to bring it in and they'd check for viruses which they were "certain I had" ROFL.
I finally talked to one place where the guy seemed, relatively knowledgeable. He told me to bring it in, I could watch him and what not.
I drive up to his place, walked in... Saw dozens of CRTs, 10 year old GPUs, PowerPCs from the 90s. I'm like this guy repairs people's Dells, not good, not good.
So I let him get to work, and fter I watched the guy bust one of my PCI-E locking clips while trying to pull out my GPU not knowing they slide open to unlock first either out of idiocy or he didn't care, and then telling me straight faced it was no big deal he'd glue it back.
I got pissed, put everything back together myself, said some pretty bad words then walked out.
I have looked around, there isn't really a legitimate place where I'd trust someone to mess with my rig. I mean there's MicroCenter and Best Buy and crap like that. But again half those people are there to remove some old lady's viruses and they don't guarantee crap if they break it.
For some reason looking at these pictures through the forum/Firefox/whatever, seems to lessen the banding compared to the originals on my computer or even saving these pictures on my computer. I don't know why, but makes me a tad optimistic. On my rig the original pictures, are intense, the banding is instantly noticable. Yet on Firefox from the uploaded ones, it's mild and honestly not horrible but ti's there.
But I've looked at the pictures on an iMac we have downstairs and on sister's laptop. They are harder to see on those, the iMac especially with it's native dark gamma or whatever.
On the Mac the first picture you basically can't see the banding since their screens are so dark to begin with, but 2nd picture you can on the right of the character over the bridge down in the hazy area.
On the laptop I can see them, again it's harder since it's on a 15inch screen.
Believe me I did look at screenshots from my computer on other computers first, because I was hoping to hell it was the monitor and if I couldn't see the issue on another computer that would definitely mean it was the monitor.
Actually after I looked for banding on screenshots on the Mac I was happy as hell because I figured it had to the be the monitor since I really didn't look that closely. I spent the better part of the day after that messing the monitor trying to calibrate it. Needless to say I wasted that whole day.
I went back to those screenshots on the Mac, looked closely. And then I saw it, turned up the Macs brightness and boom...
Maybe this problem is worsened by the calibration of my monitor, well monitors since I've gone through 4 now err 6 if you count my old ones that show the issue as well. But, it is there.
I have lessened it by completely turning off the gamma on this IPS, but there is other problems associated with trying to minimize the banding.
I normally have my PLS panel monitor on fairly dark but now when I drag your pictures over to my other screen I can see them. I think if you have tried pretty much everything out there including a motherboard swap and everything else the only two things that I could think of are that your ram may not be fully compatible with your motherboard even though I know you swapped it. or it's the processor you can try just going to your bios and disabling the turbo. but if you have like $40 you could try ordering this http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=7651322&SRCCODE=LINKSHARE&cm_mmc_o=-ddCjC1bELltzywCjC-d2CjCdwwp&utm_source=Linkshare&utm_medium=Affiliate&utm_campaign=8BacdVP0GFs&AffiliateID=8BacdVP0GFs-tLpZIxrT3_.2Q8YATR1glA just to try it. I just don't really see any other possibility. You could try something like downloading a windows 8 just to try it out and see if for some freakish reason there is a driver issue between the windows 7 version and the windows 8.
First off, thank you for all your suggestions and help. I know my issue probably isn't the easiest, I generally try to do everything myself first before asking others, but having other people try to help is nice and sorta lessens my frustration.
I'll definitely try checking more of the BIOS settings including Turbo in the morning. I'm not gonna mess with any RAM/CPU voltages or other stuff like that, as I'm not familiar or comfortable with it. And they have all been default and remained unchanged even when this problem wasn't present.
I could grab a cheapass compatible CPU and try it out, but honestly I think I'm at the point of just sticking with software/configuration troubleshooting. After putting in this last GPU and checking RAM slots with specific sticks(again) this afternoon, I've probably reached the last of what I can muster hardware swapping wise unless someone can truly convince me they're 100% on knowing a certain part is doing something that I haven't already ruled out.
I mean I'll probably spend an hour or two day like I have for the last 8 months trying to find something I've missed, but I think I've passed the point of gung-ho hardware swapping. It just adds more frustration upon the original frustration of the problem, when it doesn't pan out. Plus I don't exactly enjoy messing with parts after the put a rig together, I know I'm not gonna mess anything up, but it still kinda scares me. I've built 4 rigs now, and every time, even though it goes smooth(have been lucky so far in that regard, this is actually only the 2nd issue I've ever had regarding computers I've built and they all happen well after the computers been running for awhile), I still freak out. Maybe if money wasn't a concern, it wouldn't be so bad or nerve wracking, who knows lol.
It really pisses me off though, this computer runs so well, without any performance/stability issues. Every game I've thrown at it runs maxed at 60fps, well except DayZ-SA near towns/cities but that's bottlenecked by the CPU and poor optimization of the engine and that's in Alpha/Beta granted it was like that in the mod/Arma2. I do want to recommend EVGA to anyone though, their Customer Service is absolutely stellar, and since I can safely assume their cards were actually not problem since well I've gone through nearly a half dozen of them. I mean what company is gonna ship you out that many cards to test, pay for the shipping and not charge you? I mean I only had a basic warranty from buying the original at local store. ASRock on the other hand, complete non-existent support, hell they don't even have a phone number for tech support. When you finally can get a hold of someone through calling their Sales number and bullshitting your way to someone who can do something, it will be over 2 months before you can get mobo back.
Anyhoo, thanks again, I do appreciate all the time you've spent replying.
