8 ohm receiver plus 6 ohm speaker
Fuzziekiwi
45
Hey, I have a Pioneer reciever vsx-d608 and was looking at Elac B6 speakers, but I was wondering if this would be bad because my receiver (i think) is 8ohms while the speakers are 6ohms? Could I damage the amp or speakers?
The Elac B6 aren't designed to be a difficult load. They don't go below 6ohms so it should be OK.
There is no danger in damaging the speakers but it might damage the receiver.
In most cases the receiver will go into protection rather than blow up.
Here is your answer.. http://www.tomsguide.com/answers/id-2879066/ohm-speakers-ohm-stereo.html
It should be fine. I have used 8ohm receivers with 4 or 6 ohm speakers in the past (Bose speakers).. the only real thing is the volume will be different if you used to use 8 Ohm speakers and now have 6 ohm it uses a little more power then the 8 ohm. you should be just fine though as long as you don't push the receiver to like 100% volume. IN reality you probably will NOT notice any difference.
other side note about the 100% volume IF you push the receiver so its super loud you do have a chance to overload the receiver.. so it is better to always match the specs if you can but you darn should be just fine and dandy (if you don't try and push it to ear splitting volumes.
