8 pin 12V Cpu connector too hot
ANIL YALCIN
21
Hello TH.
As i write, my psu's 8pin 12V connector cable too hot, its burned my old motherboard (GA 990 XA UD3 Rev3.0) and i have now ASUS M5A97 R2.0
my psu CM-RS ACAB M2
what can i do please help me.
The connector melted because it had too much resistance--hence why it got hot. Replacing only the motherboard side may not fix the problem but replacing both sides will for sure.
If you have no warranty left on the CM just cut a good EPS12v plug off one of your dead power supplies and splice it onto the CM. Then you can use it safely until you get a better power supply.
I have old 750W Thermaltake PSU. don't remember model, it was burned i think. it was blown fuse. and the other one 550W psu has exploded. i think its transistor or capacitor.
My old mobo's 8pin connector has melted cause PSU. I don't wanna more problem. plz help me
i don't have too much money novadays but i don't wanna burn them all
I have this components now
ASUS M5A97 R2.0
AMD FX-6300
ASUS GTX660 TI DIRECT CU-II
is that psu enough for me?
http://i.hizliresim.com/LQyNvo.jpg
As i remembered, it wasn't too hot old days. now every power supply has same reaction
im asking for it can you look for this
