8 pin 90 degree GPU power cable adapter?
lostmenoggin
203
Trying to neaten up the inside of my PC and was wondering if anyone has found a 90 degree adapter for the GPU power cable. I have to bend the current cable out of the way to get the panel back on and I think it would look neater if the power cable had a 90* bend where it plugs in to the GPU. BTW I need 2 8 pin for my GPU. Been searching but no luck so far..
