I want so swap IPU's but stumbled upon a problem where 8-pin cable from IPU won't go in the graphic card. Right now with old IPU it works by 6+2 pin and new one is just 8-pin.
With IPU, are you referring to the power supply unit or the integrated graphics in the CPU?
In my post below, I'll refer to the power supply unit (PSU) and not the iGPU graphics processor in the CPU, and also the dedicated graphics card in your picture (GPU)
You have to use the 6+2-pin for your 8-pin on the GPU.
The extra 2 pins, attatches to the 6-pin, and will act as an 8-pin when pushed into the GPU connector
To me, it looks like your are holding an 8-pin for the motherboard in your second picture, although I can't be 100% sure.
But that won't fit in your GPU if it is in fact an 8-pin 12vEPS connector.
Don't try to force anything or use somekind of adaptor, they are shaped differently because they can't be used for anything but their intended purpose. One is for CPU power, the other is for GPU power
If it isn't the 12V EPS 8-pin you shared a picture of, it could also be the end that is supposed to fit into the PSU if it's a modular design, which also won't fit into your GPU
6+2 is the one you should use
If you by IPU mean integrated graphics (iGPU), the answer will be a different one
Thanks for the picture, it makes it a lot more clear
Yes. The cable you need, should have 8-pins on one end that attaches to the power supply - into one of the blue connectors on the power supply in your last picture. It reads 8pin PCI-E
On the other end of same cable, there should be a 6-pin with an extra 2 pins
The additional 2-pins can be combined with the 6-pin, thus providing the correct 8-pin for your graphics card
Just to make sure, you are using the cables that came with the PSU, right?
It is essential to make sure that cables from a different PSU are compatible with the one you intend to use them for, before you use differnt cables than original. It can potentially go very badly wrong if you use incompatible cables
The correct cable should be provided with the PSU, if you bought it from new.
If it is second hand, you need to find out, if CoolerMaster sells a replacement cable set for your PSU model. Or you can have cables made, that fits your PSU. Cables from other manufacturers can sometimes be used, but when doing that, make sure to double check compatibility before installing them. Not just if they pshysically fit into the socket, but also pin-out
Remeber - always use original cables, or make 100% sure that unoriginal cables are compatible with your exact model of CooerMaster power supply
One thing I have thought of since my previous post is that, considering the layout of the pin connections on your PSU, and the way they clearly diffentiates between 6-pin and 8-pin, it could possibly be, that the connectors on both ends of the correct cable, could have 8-pin.
But generally, the layout seen more often when it comes to PCI-e power, is 8-pin for the PSU and 6+2 for GPU
Also, because of the coloring of the sockets on your PSU, the right cable can possibly have the same color plastic on the cable connector, so it is easy to macth what cable goes where
So in short.
Look for the 8-pin cable in the included cable set for your PSU, that fits into the blue 8-pin socket on your PSU labeled "8pin PCI-e"
The other end should have a 6+2-pin (or possibly a complete 8-pin in ypur case).
Both connectors need to fit perfectly, otherwise they are not the correct cable. The correct cables should be included with your power supply. You shouldn't need to look elsewhere for cables
Could you possibly provide the exact model of the CoolerMaster power supply you have?
With the correct model, it would be possible to be a little more specific when answering, than what I've been able to so far
If it is second hand, you need to find out, if CoolerMaster sells a replacement cable set for your PSU model, if you don't have them already
So in short.
It is second hand, only modular cables left on it are for hard drives.
This is very important, and would have been good information to include in your original post. Actually I think it is crucial information to add in your original post
If I guided you towards using some cable that could possibly fit, and I didn't know it wasn't an original cable, and you connected it and tried to fire up your computer, it might very well have destroyed everything connected to the PSU, in a worst case scenario. I would feel awful having guided you in that direction
THESE replacement cables should fit the model name you provided, but personally I would contact CoolerMaster and let their support tell you specifically what cables fit
The reason for contacting support is, that all CoolerMaster cables, doesn't fit all CoolerMaster PSU models. They are not all interchangeable between all PSU series, even if they are all CoolerMaster branded
It is essential to understand how important using correct cables for a PSU actually is.
Using wrong ones can lead to severe hardware damage if they are not compatible. Don't underestimate how wrong things can go with regards to PSUs
