I'm trying to squeeze a gaming setup into as small a case as possible - I've got a little Kolink Satellite plus case. I bought a semi-modular PSU, where plenty of the cables are optional, the main ones fixed.
The GTX 1070 I've got physically fits in the case, but blocks any of the plug-in power cables, so I'm hoping that the power I need will be alright from the main lead - Aside from the motherboard power and the sata power, there's an 8-pin, half yellow leads, half black. It looks the right size for the 1070's 8 pins, however the shape of the pins means I can't plug it in. (It's also a bit of a squeeze, as it plugs in at the exact point that this PSU chooses to have the cables coming out!
It has been a few years since I assembled my own so I'm probably being stupid, but is this cable OK to power the 1070? Or what else is it for? Can I get an adapter to make it fit? The instructions I'm sure say that the yellows are all 12v, and the blacks 'COM'.
I'm thinking if the pins are the wrong shape then it can't be the right arrangement of + and - so perhaps if I knew what it was called I could find an adapter to rearrange it!
Any ideas?
Any advice appreciated!
Any ideas?
