So I got my hands on a new GTX 1060 from Gigabyte for next to nothing. However when I went to install it I noticed something odd concerning the connections. So my old card (GTX 570) runs with 2x6 pin PCIe, but the new card requires 1x8 pin. So I have a 6+2 pin running from my PSU but on the PSU end the 8 pin connector only has 6 wires running out of it, being two GND wires missing. Is this normal on the PSU end, I figure the ground wires on the GPU end might just be wired into the other ground wires already there and perhaps the gauge has been upped.
Will I be fine connecting the 8 pin with two missing wires to the 6+2 into the GPU, this is the only PCIe cable apart from a 6 pin one that came with my PSU. Or should I look into a 2x6 pin to 8 pin or something like that?
My PSU is a: OCZ600MXSP
Thanks in advance
Thanks in advance
