Question 80-83 c temps normal for a two fan gesign 2080ti?
Sep 29, 2019
23
my zotac twin fan 2080ti reaches 80-83 c under max load in games like witcher 3 and gears 5 1440p ultra,are these temps normal?
Aug 16, 2019
25
Dont sound good but im not an expert on Graphic card normal temp But the most of the card i had hit like 50-70C but try change the thermal paste maybe but im not an expert so dont do it now just get en better answer by an expert
zero_l0gic
Commendable
Aug 17, 2018
360
4
1,215
108
80ish is max (to say it ok) so you are on the edge, how old is the card? Does it have enough airflow around it? Do you OC it? Saw reviews for the card it looks like that is the cooling performace they report from 75-85c depdends on room temps and airflows (opencase-closedcase).
Sep 29, 2019
23
The card isn't old or anything,built the pc on 4th October,isn't overclocked,air flow,I wouldn't say it's the best,I haven't installed any extra fans or anything
