[SOLVED] 80 C° too hot for Roblox?
Dec 30, 2018
I have an Aurora R7 Alienware pc which contains a 1080 gpu, i7 8700 cpu, 16 gigs of ram, 2 tb of storage with a 32 gig intel optane which I got got frys. It was a display floor model. Is 80 C° too hot while playing Roblox? Also it's very loud because it's so hot. Is that normal? It has a stock fan btw.
80C is still safe, but I would start worrying once it hits the upper 80s/90s because it will likely start throttling. I definitely recommended buying an aftermarket cooler because even the super cheap ones will run better than the stock fan.
I feel like 80C with those specs and while playing Roblox is a little high. I would check if there's dust packed near your fans if your system is old, and I would recommend you to invest in a good cooler to replace your stock one.
