80mm "Case" fan on CPU heatsink OK?
voxleo
47
I actually posted the meat of this in the CPU section since I'm not at all familiar with overclocking, but this seems the more appropriate section...
Is there any reason I can't use an 80mm "case" fan screwed to the top of my 478 socket heatsink to replace the busted intel stock item (c332318-002) for a 3.2 Ghz Northwood /512/800 P4 on my ASUS p4p800e-dlx? what kind of specs would it have to have if that were possible?
I also have an older solid aluminum bi-directional with a foxconn on top from my 1.7ghz VAIO would that fan/sink work better than the 4 way copper-core with a case fan on top?
Or do I have to find a new 478 cooler altogether (which is getting harder to do)? And if so anything decent for under 20 bucks?
voxleo
47
w00t! totally bitchin'!! Thanks, saves much effort and fundage!
Any thoughts on the heatsink - is the solid aluminum bi-dir or the copper core 4-way a better base to use for such a thing?
