So I posted one of these a little bit ago, but my time frame and budget changed a little. I also came to the realization that I'm kind of struggling as far as the motherboard goes, so I'd really appreciate some help on that part. I'm looking for the best value for money from all my components, and I'm not really sure how to go about getting that from the MB.
Basic things I want from the machine: Edit photos with Lightroom 4 or Photoshop Elements 10 while streaming music from Google Music or 8tracks.com. Play Team Fortress 2 (pretty easy, but I want it to run like butta). Watch sports on WatchESPN. Play Starcraft II or some of the newer Assassin's Creed games. I'd also love it if I could do all this on a dual monitor setup.
Approximate Purchase Date: Early - Mid January
Budget Range: around 750
System Usage from Most to Least Important: Editing photos with Lightroom while streaming music, casual gaming, watching sports online
Are you buying a monitor: No
Parts to Upgrade: Everything - completely new build
Do you need to buy OS: Probably - not sure if I want Win8 or not yet
Preferred Website(s) for Parts: I usually get stuff from newegg.com, but I'm open to shopping at others
Location: Nothern VA - have a MicroCenter nearby so those will probably be the best in store deals
Parts Preferences: These are preferences, but I'm open to suggestions.
Intel CPU - this one is a definite
Antec case, Corsair memory, Seagate HDDs, Corsair PSUs
Overclocking: Not right now, but Maybe in the future to extend the life of the system
SLI or Crossfire: No
Your Monitor Resolution: My main monitor is 1920x1080. I also have one a friend gave me that I'd be interested in trying to use in a dual monitor setup.
Additional Comments: Don't need bling or anything. Just want it to be reliable and to last me for a number of years.
I'll be using Lightroom 4 to edit photos and I'll do a little casual gaming. Games I play are Team Fortress 2, Starcraft 2, and I'd like to play some of the newer Assassin's Creed games.
And Most Importantly, Why Are You Upgrading: Current system is getting long in the tooth. Can't run Lightroom and stream music at the same time like I want. Also can't play some of the newer games I want to be able to play.
Parts I've picked so far. I'm not totally wedded to these, and as I stated above I'd really appreciate some guidance on selecting a motherboard.
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
SAPPHIRE 100355OCL Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card OC Version
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102999
CORSAIR Enthusiast Series TX650M 650W ATX12V v2.31 / EPS12V v2.92 80 PLUS BRONZE Certified Semi Modular High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139031
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMX8GX3M2B1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233202
Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
ASUS 24X DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model DRW-24B1ST/BLK/B/AS - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
