ZeusGamer Admirable Jul 9, 2014 1,647 1 6,165 Jan 20, 2016 #1 Is this PSU enough to power an Intel 4770K at 4.5 GHz and two GTX 980 in SLI? Wanting to overclock the GPUs as well but I'm not sure if the PSU can handle it.
Solution Dark Lord of Tech Jan 20, 2016 Yes it is a perfect fit for your needs. Plenty of high quality power. 😀 Made by the best in the business Super Flower , I own it you won't be disappointed.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,744 1,825 159,590 Jan 20, 2016 Solution #2 Yes it is a perfect fit for your needs. Plenty of high quality power. 😀 Made by the best in the business Super Flower , I own it you won't be disappointed. Upvote 0 Downvote Solution
SPgamer007 Honorable Nov 17, 2013 1,630 0 12,460 Jan 20, 2016 #3 That's actually a really good PSU. You'll get more than enough Power. 😉 Upvote 0 Downvote
RCFProd Expert Ambassador Dec 8, 2013 12,605 29 56,990 Jan 20, 2016 #4 Maximum power draw is about 285w each gpu. Your system use should be below 750 watts in all situations so that's plenty of headroom. Upvote 0 Downvote
g-unit1111 Titan Moderator Jul 27, 2011 42,756 857 104,940 Jan 20, 2016 #5 One of the best units you can buy for the money. I have two of these and they are very well built and should last a very long time. Upvote 0 Downvote
ZeusGamer Admirable Jul 9, 2014 1,647 1 6,165 Jan 20, 2016 #6 Thanks a lot you guys. I ordered it and it should arrive on Friday. Upvote 0 Downvote
