Hello Everyone, I am looking at upgrading my computer for my home based recording studio and I am trying to decide between the 8700K and the Ryzen 1800X. Either one I get I will overclock as I have an Arctic Liquid Freezer 360 AIO. The Ryzen chip likely to 4GHz and the 8700K probably closer to 4.7-4.8GHz (I will not go so far as to Dellid the processor or using Liquid Metal though, even though I do have it and have used it in the past). I might do some video editing as well and maybe even light to moderate gaming but primarily this computer will be for music production and recording. I read online reviews from ScanProAudio that the Ryzen 7 chips had issues with not being able to refresh its cache quick enough for low buffer latency as well as Intel but then again that was very shortly after its initial release so I am sure that perfomance has improved with updates since then as those figures were back in March of last year. Also since that time we have had Meltdown and Spectre so both of those could affect the end result as well. Not really sure. I have 2 builds that I am trying to decide between.
Intel i7 8700K $349.99
Asus Z370 ROG X Code $289.99
Or
Ryzen 7 1800X $299.99
Asus Crosshair VI Extreme $319.99
As you can tell, Price is extremely similar. I also think that the 1800X is likely a better binned chip that the other Ryzen CPU's so since I live over an hour away I want to get a you with the best Overclock potential for 4GHz+. My other components are an XFX R9 295X2 Graphics Card, 32GB Kingston HyperX 2666 DDR4 Memory, An EVGA 1600W Platinum power Supply, and a Corsair 780T case. The most important additional aspects of my system are reliability aince it is going to be used with clients. No matter which of the two I go with both the CPU and Motherboard will be replaced within 3 years since I will uphradr before my product service plans end so upgrade path means little to me as both components will be replaced anyway. Does anyone have any feedback as far as these two processors as far as which one will be the best for my needs? Thank you in advance.
Or
