Hi all, I am a beginner at CPU overclocking. I'm using a non-delidded 8700k with a Corsair H115i cooler
I started trying at 5GHz and 1.35v, but CPU temps were approaching 100 degrees under load. I tried 1.3v, than 1.275v, and it still seems stable.
At 1.275v and 5GHz, I can run RealBench 2.56 stress test with memory set to "Up to 16GB RAM" for 4 hours without going over 90 degrees or having any apparent instability. Based on my searching the forums, this seems to be a good result for this CPU.
Should I keep trying to lower the volts, or just be happy with what I got? I figure that if I go with the lowest volts that can "pass" RealBench, it might not be enough for real life tasks. And a max of 90 degrees should be fine, right?
