Question 8700K Temps Problem
BreaK_TV
Commendable
Sep 29, 2016
38
MY PC
Case: InWin 805 Black
Procesor: i7-8700K CPU @ 4.70GHz
Motherboard: MSI Z370 GAMING PRO CARBON
Video Card: GeForce GTX 1080 Ti AERO 11G OC
DDR: 24GB DDR4 2400 MHz ( 3X8 GB)
SSD ADATA Premier Pro SP550 Series 128GB
Samsung SSD 850 EVO mSATA 1TB
Chieftec A-90 Series GDP-550C 550W
Microsoft Windows 10 Pro
Last night i wanted to render with adobe premiere 5 dvd, 1 hour each one, after some time my temps where going to high... around 90+... i reseted the bios setings and the issue was still there... temps where to high after 10-20 minutes of rendring... I made a test with aida 64 stress test and even there temps are going over 86... any solutions or help whould be great. Thanks
I have a liquid cooling sistem on my pc from cooler master with two fans, but i don't know exactly the name...
Photos Here
https://i.imgur.com/iHWPkTJ.jpg
https://i.imgur.com/uFzWx8s.jpg
Try out these steps or skip some if not nessesarly:
1) If the system is pretty old, blowing out dust from your case with air helps a lot. if it is a newer system or you don't see any dust in your pc, then skip this part
2) Cables might be a problem. they always say to organize your cables correctly as this improves the build in heat in your pc. but because it is liquid cooled, this might not be the case
3) applying new thermal compound to the cpu might be the solution. make sure the compound is good quality and apply the right amount. to little and your pc overheat to easly. to much and you get a mess over your motherboard, as all that thermal compound melts over your motherboard, jikes.
thy these out. and be carefull with overclocking would ya 😉
i'm not sure what the line means, but the counter below says that the temperature of your cpu is 41"C, which is quite good?
looks like there isn't anything wrong with your pc, but you've seen something else and got worried by it.
might want to know what that line means?
I managed to make the pump work by conecting it to the cpu fan 1 and now is working 100% only when the temps are over 70, i added two more coolers on the radiator ( two in the front and two in the back, and after running aida 64 for 10 minutes the max temp was 84, and the temps where betwin 79-84. I will run a render test with premiere pro and see how the temps are when rendering with premiere pro...
https://i.imgur.com/lsu3YEb.png
https://i.imgur.com/HFiGuVd.jpg
SkyNetRising - the front is covered with glass... i quess this could be an isue, but i have one question, now i restored the dephauld bios setings and the temps are like going crazy.... if i run aida 64 stress test with bios dephauld settings the temps are going over 90 and the cpu is throttling - overheating... i don't get it...
