8gb + 4gb ram Hyper X Fury Same Timings ,Model And Speed
Carol Anthony
26
Hi. I Have A Question If I Have 1 stick of 8gb ram and 1 stick of 4 gb ram will it activate the dual channel memory ? and will it will increase his peformance ? because if i have 8 gb 1 stick some is unplayable and i accidentally bought the 8gb and dont have budget for another 8gb
Cost For Hyper X Fury 4gb:850PHP and For 8gb is 1700PHP
BUDGET: My budget is only 1000PHP
Specs:
CPU:Amd-A8-7600 Turbo Core Disable)
RAM:Hyper X Fury 8gb 8x1)
Mobo:Gigabyte GA-F2a68hm-s1
Cooler:Stock Cooler of Cpu)
Nope, for dual-channel your sticks have to be the same timing and same size (4GB + 4GB, or 8GB + 8GB), & usually also need to be the same brand/model.
However, since you'd be increasing your available RAM by 50%, you should see a performance boost from buying it.
Latest posts
