8gb enough or more for Flash CC??
Youssif94
16
Hi everyone, i wanted some help to know what to buy next for my Pc,
I want to know what best helps Adobe programs? most of the time using Flash CC
i have an avg. rig
750ti/fx8320/8gb i have around 35~40$ only which is enough for either a 8gb stick, or a cheaper SSD like silicon power, or for few $ more a 1TB HDD
Flash was working fine, the moment i started going up to 400-500 frames it begins lagging little bit and crashes more often and choosing/selecting big amount of frames in the timeline would cause it to freeze few seconds till the selection appear, its really getting annoying especially with the crashing and loosing work....
Not quite sure what you are asking or are saying. If you are trying to decide between more memory or a better drive the best option might be . . . How much memory do you have now? More memory will improve the freezing issues, maybe depending on how you have the OS set up as Adobe programs are memory hogs. An SSD will improve access times and speeds. A larger hdd will give you more storage space but will perform about the same as an SSD except slower for access times. These are really three separate issues.
W.P.
