8Gb Ram installed and 3.95GB usable??? PLEASE HELP!!!
Thanks for the reply.
I have just re seated my ram and there was no change in usage and i;m about to do a RAM test using the built in windows one. I'll get back to you with the results.
That would be my guess, but that doesn't explain why the memory test saw slot 2-4.
I'd put the old cooler back on, and see if it still works with slot 1-3.
I know it sucks, but computer trouble shooting is a series of long boring tests, you have to love it.
I could be a bad memory slot.
When you have access to all slots, try 1-2 and 3-4.
I know you won't get dual channel, but may tell you if all the slots work.
Try 1 stick in all slots.
Test with every combination you can think of.
