8gb versus 16gb and 1600mhz versus 2400 mhz
Taytotom83
68
The clue is in the title.
I'm currently using a 2x4 RAM Config at 1600mhz, how far would performance increase if I were to be using a 2x8 2400 mhz config?
I have a dual monitor setup and use my PC mostly for gaming and watching streams
For gaming I would recommend 8 GB; if you get into more memory intensive applications such as video editing, 3D Modeling, CAD work, compiling etc. I would recommend 16 GB. Keep in mind, more memory in excess of what you use can bring more cons, than pros. Aside from the added cost of buying more memory, it can result in additional latency due to memory mapping. Higher frequencies can result in higher voltage draw (1.65 V is typical for DDR3 @ 2400 MHz) and higher Column Address Strobe latency in order to maintain system stability. Increases in voltage will also increase your RAM temp.
In short, the law of diminishing returns kicks in and 2400 MHz isn't necessary for today's level of gaming. 1600 Mhz should be sufficient and you...
Your RAM config is more than enough. 16GB is overkill and there is very little difference between 1600 MHz and 2400 MHz
Very little increase in performance
you'll get an increase in performance on benchmarks and that's about it. you may see a 1-2% increase in performance on certain games, but that's not noticeable. don't bother with the upgrade, wait a few years, and build yourself a DDR4 memory based system
I wasn't planning on upgrading, I was just wondering if it could make a difference. Apparently not, thanks for the info!
In short, the law of diminishing returns kicks in and 2400 MHz isn't necessary for today's level of gaming. 1600 Mhz should be sufficient and you shouldn't notice any difference if gaming is your primary concern.
