M mrea13 Dec 25, 2018 9 0 10 Dec 31, 2018 #1 Only I motherboard that has 8-pin power at the top can you only plug in 4 of them.
Solution Dark Lord of Tech Dec 31, 2018 Sometimes 4 will work on lower end setups. If a PSU only has a 4 pin it shouldn't be used on today's hardware.
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,614 1,778 159,590 Dec 31, 2018 Solution #2 Sometimes 4 will work on lower end setups. If a PSU only has a 4 pin it shouldn't be used on today's hardware. Upvote 0 Downvote Solution
