8pin PSU to 4pin CPU power conector, what to do?
If the motherboard has only a...
The 8 pin EPS male auxiliary power connector is often fashioned as a 4+4 pin connector such that it may fit into a 4 pin ATX female auxiliary power receptacle. Connect only half of it, that's how it's designed.
will I lose anypower from it ? I read a forum telling that if i conect only half of it, i coulnd't have all the power i need for my 125watt CPU. I have a 600watt PSU.
If the motherboard has only a single 4 pin auxiliary power connector it does not need more power. That will provide enough for a 125 watt CPU, just don't throw a 9590 in there
