M Misha_2 Commendable Apr 30, 2016 11 0 1,510 May 26, 2016 #1 I am looking for a 90° sata power cable but all i can find is molex to SATA power. I dont want to use the adapter, so can anyone please tell me a SATA to SATA cable. Thanks
sanzufin Reputable Aug 13, 2015 77 0 4,660 May 26, 2016 Solution #2 Where do you need that cable ? Upvote 0 Downvote Solution
M Misha_2 Commendable Apr 30, 2016 11 0 1,510 May 26, 2016 #3 sanzufin : Where do you need that cable ? I want the cable In my case. The cable mgmt in my case with the storage devices is just awefull Upvote 0 Downvote
M Misha_2 Commendable Apr 30, 2016 11 0 1,510 May 26, 2016 #4 sanzufin : Where do you need that cable ? Plus how do i make you now the best anser? I am new here 😛 Upvote 0 Downvote
sanzufin Reputable Aug 13, 2015 77 0 4,660 May 26, 2016 #5 Misha_2 : sanzufin : Where do you need that cable ? I want the cable In my case. The cable mgmt in my case with the storage devices is just awefull my earlier comment is now "The solution" http://www.newegg.com/Product/Product.aspx?Item=N82E16812198014&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-Skimlinks-_-na-_-na-_-na&AID=12087162&PID=3899435&SID=skim1402X558040X7a9fa612d1806bf310983e26ef551f0a&utm_medium=affiliates&utm_source=afc-Skimlinks Upvote 0 Downvote
SkyNetRising Titan Jan 4, 2016 31,836 4,499 126,640 May 26, 2016 #6 You mean - this one? http://www.ebay.co.uk/itm/Sata-Powe...20cm-Male-to-2-x-Female-doubler-/191809416107 Upvote 0 Downvote
M Misha_2 Commendable Apr 30, 2016 11 0 1,510 May 26, 2016 #7 SkyNetRising : You mean - this one? http://www.ebay.co.uk/itm/Sata-Powe...20cm-Male-to-2-x-Female-doubler-/191809416107 YES! thats the one. Thanks man Upvote 0 Downvote
