Caption says it all.
All i can find on various platforms (Amazon, Ebay, AliExpress and affiliates) .. are 90 degree adapters WITH senses pins.
The problem is .. the RTX 3070 does not make use of the sense pins .. and the connector does not offer any space to plug in an adapter with sense pins (Founders Edition)
So .. does anyone know a (preferably low profile) 90 degrees connector for a 12 pin GPU without sense pins?
Reason for that possibly unusual question. When i place the GPU into the case vertically, i have to bend the original 12 to 8 pin adapter cable quite strongly .. so much that i do not feel is "healthy". It interferes with the scythe fuma cooler tower. There is roughly 1cm space ... and while i CAN bend the cable, it does two things .. push the GPU down and push the cpu coller up, putting strain on the pcie mount as well as possibly interfering with the CPU cooler contact to the cpu.
