I'm from Canada, I want to build a budget pc and use my older parts as much as I can. My total budget would be 800-900$.
I currently have :
Thermaltake Tr2-430W (power supply)
EVGA GT430 1GB DDR3
Asus M3N78-VM (motherboard)
Crucial 2GB DDR2 (Ram)
AMD Phenom 8750 triple core
Samsung HDD 1TB
Philips DVD/CD player
I want to build a good machine with decent gaming output (Civ5, Lotro, Serious Sam3, Casltevania Los2, Sose) on high settings. I also plan on playing futur games, so graphic wise, I'm aiming for the best I could afford.
I'm considering keeping my old tower, monitor, Cd player, mouse, keyboard, hard drive and maybe my power supply, if it has enough power to supply my new build.
Here is the prospect of my new build:
http://pcpartpicker.com/user/olay/saved/3RNk
I intend to use bot HDD and SSD together for the increased performance of the SSD. But if the money could be spent on better hardware I can use only my HDD without any problem.
I want to know what do you think of my build, which power supply would you recommend me and if you have any suggestions for better parts than those listed on my prospect, considering that I will spend maximum 900$ on the whole setup.
I based my build on the information I gathered from this website (8 hours worth of time). I'm sure I could find my answer if I search long enough, but considering my modest knowledge in computers, I figured out that asking your advice directly with what I managed to gather would be wiser.
Cheers to all the pc enthusiast around the globe!
... and pardon my english, I'm french.
Olay
I currently have :
EVGA GT430 1GB DDR3
Samsung HDD 1TB
Olay
