[SOLVED] 90mm case fan have the same mounting hole spacing as 92mm?
clutchc
Ambassador
As stated in the title, I'm trying to find a 92mm PWM case fan with blue LEDs. Can't find one. But I did come across a 90mm fan that would work... if the mounting hole spacing is the same as 92mm. Can anyone answer if it will work?
90/92mm fans are interchangeable. I haven't quite figured out why some are labeled 90, some 92, but if you go and a 90mm fan and a 92mm fan, and lay them on top of each other, they're the EXACT same size.
