915€ mATX 1440p max settings gaming build, will this work?
It is a link to mindfactory.de, which is the biggest/cheapest german hardware seller. I already tried putting this list together on pcpartpicker, but unfortunately it doesn't pick all the products from their site correctly and so it does not include the best offers.
Here is the link again in text form:
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/cd8d4e221f348501a2b9d015443460a75e5b848c57dce57bb83
Here is the basic config in text:
Intel Core i5 6500 4x 3.20GHz So.1151 BOX
ASRock H110M-DGS Intel H110 So.1151 Dual
8GB G.Skill Value 4 DDR4-2400 DIMM CL15
240GB Intenso High Performance 2.5"
2000GB WD Blue WD20EZRZ 64MB 3.5"
450 Watt Seasonic G-Series Modular 80+
8192MB ZOTAC GeForce GTX 1070 Mini Aktiv
Zalman ZM-T4 Mini Tower ohne Netzteil
As the Gtx 1080 in higher specced systems doesn't even reach constant 60+fps in some games on MAX settings at 1440p, I already know this won't work. It's a great build, but you will have to put some settings down in certain games.
Thanks for the answer! Makes sense, it seems there are some really resource intensive settings on certain games. But I'm already satisfied if got the most out of my budget and that you didn't find any obvious errors.
