9600 Pro, 9700, 9700 Pro? Advice?
n1teowl
4
Any advice on which of these to purchase would be appreciated. 9600 Pro for $156, 9700 for $237 or 9700 Pro for $305. I could afford any of them, but I want the most "bang for the buck". Thanks!
Then get the 9600 PRO, clearly the best price/performance deal of the three.
<A HREF="http://forumz.tomshardware.com/modules.php?name=Forums&file=profile&mode=viewprofile&internal=1&username=Boozehound" target="_new">My System</A>.
Obviously the 9700 pro will give you the best preformance. If you can afford it do it. Otherwise the 9600 pro overclocks quite nicely, <A HREF="http://www.hardocp.com/article.html?art=NDY0" target="_new">see here</A>
Where do you live?
In the US you can get 9700 non-pros for around 200-215, which would definately be your best bet, offering significantly better performance than a 9600 Pro, and also being able to overclock.
Get a Sapphire or Power Color 9700 np, you should be able to find both for around 200-210.
"Mice eat cheese." - Modest Mouse
"Every Day is the Right Day." -Pink Floyd
Thanks for the feedback. I'm having difficulty finding a 9700np in stock anywhere, especially for around $200. Any ideas where I might find one (I'm in the US)? Thanks again for your help.
