9700 pro , help me pick
<A HREF="http://www.pcwonderinc.com/atiradeon9700.html" target="_new">clickable link </A>
beat you to it Dhlucke
<A HREF="http://www.quake3world.com/ubb/Forum1/HTML/001355.html" target="_new">*I hate thug gangstas*</A>
<A HREF="http://www.pcwonderinc.com/atirad97pro11.html" target="_new">I would get this one, cause its cheaper. BUT, the BBA (build by ATI) card that is a little more expensive probably has higher quality ram. = more overclockable. Sapphire makes nice baords tho]http:// I would get this one, cause its cheaper. BUT, the BBA (build by ATI) card that is a little more expensive probably has higher quality ram. = more overclockable. Sapphire makes nice baords tho</A>
<A HREF="http://www.pcwonderinc.com/atiradeon9700.html" target="_new">www.pcwonderinc.com</A>
I would recommend a FX 5900 card, hehe. I can’t help you I’m wondering the same thing, accept for a 9800P. For a friend that is, since I’m a Nv fan :wink:
5900 is twice the price, for debatable performance increase
probalby not within his money range
The hercules one if you can find it will overclock to 9800pro speeds. The ati one will almost get you that fast, same with saphire. If you aint into overclocking, get the cheapest..... My cheapy 9700pro will only do 347/324 with a good copper cooler on it. You get what you pay for.
Can't wait to get the new hercules ati card :)
<A HREF="http://service.futuremark.com/compare?2k1=6772243" target="_new"> MY RIG </A>
<A HREF="http://service.futuremark.com/compare?2k3=1050289" target="_new"> 3D-03 </A>
<font color=red> 120% overclocker </font color=red> (cheapskate)
I don't understand your sugestion.
But I am not concerned about overclocking, ... I plan on droping it in to the AGP slot and liveing with the result, .. I will be using the new MSI MB with DOT. but that will not change clock of MB's video stuff.
oops yah i messed up the clicky thing
Sapphire 9700pro - very nice card.
ATI 9700pro - possibly better for overclocking, but more expensive
the ATI ones are cheaper though, ... the saphire is 339$
the ATI's (the first and last one, .. I have yet to figure out the differance) are 285 and 307 respecitvely.
.. I am confused, since the ATI is cheaper, .. and you say better should I then go with it.
THANKS FOR YOUR HELP .. YOU ROCK!!!
Get it if its cheaper.
