G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.storage, alt.computer, alt.computers (More info?)
I have read that to have 98 and xp dual booting - or any version of
windows - you install the old then the new. I've also heard of there
being problems with having multiple visible primary partitions.
I currently have XP on an NTFS partition. As an experiment, I tried
installing 98 without first removing XP. It worked. It detected an
NTFS partition, created a new primary FAT32 partition, formatted it,
installed Win 98 on it, and made it active.
So I have 2 visible primary partitions. I choosse which to boot from by
making it active - which can be done through PMagic or Fdisk and maybe
Diskpart.exe in XP
Since that all worked. I tried creating another visible primary
partition - this time in partition magic (with nothing on it), that
worked fine. So now I have 3 primary partitions.
So isn't it strange, that I have had no problems whatsoever with that
method, and yet everybody says to never install 98 after XP.
I'm sure I used to have to make primary partitions hidden, but here
strangely, I seem to be able to have many visible primary partitions.
WHat's the point of making primary partitions hidden if even Win 98SE
can handle it?!
And why all the fuss about having to install the old then the new - 98
then XP?
If I am going against the grain, howcome no damage is being done?
Diskpart.exe in XP
can handle it?!
then XP?
