980 Ti Power Consumption
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
So, I'm looking at gpus and psus for a first build and I think I want the seasonic g-550w. The prolbem is that everywhere says the 980 ti needs 600w. I know you can run it on a lower power supply and they're simply guide lines.
But, when you look at the specs for the msi gaming 980 Ti it says 400w. So, would I be safe with 550w?
Then you will certainly want more power and a solid PSU...no doubt about that!
Might I suggest: http://www.newegg.com/Product/Product.aspx?Item=N82E16817438034
Well, I think I want a skylake i5 overclock-able, 16GB ram, 1 HDD, and 1 SSD pretty much.
