Temperature will vary based upon the model chosen. Some models won't have the fans even turn on until the temps reach 65C. You can change that by modifying the fan curves with a tool like Afterburner. As for power used, that's not going to change much unless you put a significant load on it.
Download Furmark and run it for 20-30 minutes. In the upper left you will see temps, power and other important parameters and you shoulld equal or exceed 100%. If temps break 85C, the card will throttle itself.
The only other relevant component is the PSU. If you want to check one aspect of that (voltage stability), you can run HWiNF) while Furmark is running. Look at the voltages on the 3.3, 5 and 12 volt rails and see how they vary (look at min and max columns).... the ATX standard is 5% .... a gaming / enthusiast box should have less than 2.5% and if looking for max overclocks, you'll want less than 1%.
To see if you make it, do this:
A user here on the forum reported that his 12v rail had an 11.35v in the "minimum" column of the 12 v rail of a CX750.
12.00 - 11.35 = 0.65
0.65 / 12.00 = 0.054 = 5.4% which was outside the ATX standard.
