Hey, wondering if anyone has any ideas. I've got a 980 TI, and it's acting oddly. It used to work fine. I had it overclocked slightly and it was great. Kept it cool, typically running full load at about 60C. One day I was playing a game and noticed my frame rate was about 20 fps lower than typical. Didn't think much about it at the time. I looked into it today and the card isn't clocking as high as it's supposed to. It's hitting power throttling according to HWMonitor. Under furmark, clocks are dipping below 1000 MHz, while temps are about the same under load as before and power reported in HWMonitor is 102.5% (power target is 100% atm). I used to be getting around 1400 MHz continuously, and I haven't seen it boost past 1200 MHz today. Any attempts to overclock do nearly nothing, because the power limit pulls it back down to about 1000 MHz under load. It's also idling lower than I recall it used to, sitting at 135 MHz idle.
Anyone seen anything like this before? I suspecting a bad bios...maybe? It'd be real great to get my performance back. Anyone have any ideas?
Update: It's not the bios. I dumped it from the card and checked sha-256 against one sourced from online - they matched.
