9800 Pro's and power supplies
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
What are the smallest power supplies anyone is using with a 9800Pro (stock)
reliably?
Small power supplies as in SFF PC's and mATX cases with mATX power. They
usually have 250 or 270w at best. And there arent many mATX power supply
options.
Jones
42
On Sat, 12 Jun 2004 20:17:15 -0700, "Sept1967"
>reliably?
>options.
I suppose you'd want the one with the highest +12volts available.
Just check the specs and go with the highest. Can't be many.
G
Guest
Guest
I would be inclined to get a 400w, you can probably do it with 350 though. I
depends on how many peripherals you have connected.
http://www.jscustompcs.com/power_supply/
"Sept1967" <sept1967@highstream.(Erase)net> wrote in message
news:10cnhprq8gqa692@corp.supernews.com...
(stock)
> reliably?
> options.
Lou
209
(stock)
> reliably?
> options.
I have been running my 9800 Pro with a cheap quality 300w PS (its probably
only as good as a quality 275w PS) . Its PC with a P4 2.2ghz w/92mm cpu fan,
1GB mem, DVD-RW,DVD,SBLive,two 7200 rpm HDD's, video capture/editing PCI
card, 1 80mm case fan.
No problems with power.
I would think you might have more problems with heat and air flow for the
VGA card in a small case. I use the Arctic cooler and it blows the air out
the back.
Lou
G
Guest
Guest
> (stock) reliably?
You'd have to know the make and model, as well as other details about their
system (CPU, drives etc). The Wattage rating can be wildly misleading.
Ben
A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
Questions by email will likely be ignored, please use the newsgroups.
I'm not just a number. To many, I'm known as a String...
Gman
378
In article <10cnhprq8gqa692@corp.supernews.com>, "Sept1967" <sept1967@highstream.(Erase)net> wrote:
>reliably?
>options.
You should be fine since with the SFF mATX cases like the Shuttle series , you
have very little other things in there using lots of wattage. Only the CPU and
one HD and the 9800m Pro will not tax the 270W PS
