I am making a free build for a friend with some old components of his and of mine. I had a XFX 9800 GTX laying around and wanted to give it to him. I found that the power supply from my friend's old PC didn't have the two required 6-pin cables, so I bought a couple. The ones I could find were 8-pins, but i just split off two of them (with knife, though...) so it would fit. Now the problem is... I can boot up the computer with the 9800GTX plugged in the PCIe, but as soon as I try to boot up WITH the two 6-pins connected to the GPU, _NOTHING_ happens when i press the power button. Then I unplug the two 6-pins from the GPU, it boots up agian.
Now... What is causing this? Is it just the 500w PSU that can't handle it?
The PSU has a 12V1 15A and a 12V2 16A. I've found that the 9800GTX needs at least 26A on the 12V rails. But I know little about _this_ stuff, so I'm kinda lost; am I supposed to add up 15+16A, which leads to 31A? Or is that wrong...?
WHY DOESN'T IT BOOT?
TLDR; can ACE 500W power supply (12V1 15A, 12V2 16A) supply an XFX 9800 GTX card?
Edit: Forgot to add rest of specs...
-Core 2 Duo E8500
-4Gb Corsair 800Mhz DDR2
-MSI G41M4 Mobo
-2 HDDs
-1 DVD RW
-And the almighty XFX Geforce 9800 GTX
-Core 2 Duo E8500
-MSI G41M4 Mobo
-2 HDDs
-1 DVD RW
