kerplunkuk
89
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
My 9800 pro seems to have a power issue. Every so often it (the card) makes
a clicking noise and the picture flickers. I assume this may be a power
problem. I have a 550W PSU.
Any ideas on how to test or solve?
Thanks
Victoria Concordia Crescit
G
Guest
Guest
Overclock it and see if it gets worse (card draws more power and increases the noise the PSU has to
absorb).
Underclock and see if it gets better (card draws less power, decreases the noise)
Also, can you recreate the clicking noise and flicker by changing screen resolution via the display
properties? Might be that the card is actually resetting itself (changing resolution approximates
this, which is why I ask).
S
> card) makes a clicking noise and the picture flickers. I assume this
> may be a power problem. I have a 550W PSU.
> Thanks
kerplunkuk
89
In news:408707c6$0$14355$afc38c87@auth.uk.news.easynet.net,
Sham B <shamb@easynet.co.ukNOSP> typed:
:: Overclock it and see if it gets worse (card draws more power and
:: increases the noise the PSU has to absorb).
:: Underclock and see if it gets better (card draws less power,
:: decreases the noise)
:: Also, can you recreate the clicking noise and flicker by changing
:: screen resolution via the display properties? Might be that the
:: card is actually resetting itself (changing resolution approximates
:: this, which is why I ask).
:: S
Changing res via the display props does not seem to make the noise. Not
sure on o/c and u/c any advice?
G
Guest
Guest
"KerplunKuK" <kerplunk@greenday.freeserve.co.uk> skrev i en meddelelse
news:c66vrq$815nh$1@ID-230693.news.uni-berlin.de...
makes
It sounds more like a high voltage problem with your monitor.
I get the same symptoms when dust builds up inside it.
It causes a small shortcurcuit that allows the high voltage to "jump" and
disturbs the image on the monitor. The spark produces the clicking sound.
When I blow into the back of the monitor, the problem goes away.
But beware, if the "dust busting" doesn't help, it could also be a
developing fault in the high voltage circuit in your monitor.
Rgrds. Henrik
kerplunkuk
89
In news:40876536$0$288$edfadb0f@dread12.news.tele.dk,
Henrik Stavnshøj <hesta@nospam.dk> typed:
:: "KerplunKuK" <kerplunk@greenday.freeserve.co.uk> skrev i en
:: meddelelse news:c66vrq$815nh$1@ID-230693.news.uni-berlin.de...
::: My 9800 pro seems to have a power issue. Every so often it (the
::: card) makes a clicking noise and the picture flickers. I assume
::: this may be a power problem. I have a 550W PSU.
::: Any ideas on how to test or solve?
:: It sounds more like a high voltage problem with your monitor.
:: I get the same symptoms when dust builds up inside it.
:: It causes a small shortcurcuit that allows the high voltage to
:: "jump" and disturbs the image on the monitor. The spark produces the
:: clicking sound.
:: When I blow into the back of the monitor, the problem goes away.
:: But beware, if the "dust busting" doesn't help, it could also be a
:: developing fault in the high voltage circuit in your monitor.
:: Rgrds. Henrik
I have now noticed that my monitor now flickers on one side of the screen.
Is there anyway to test it to see if the monitor is faulty?
G
Guest
Guest
news:c694o7$932ma$1@ID-230693.news.uni-berlin.de...
Well, you could try another monitor.
Did you try to blow the dust out?
/Henrik
kerplunkuk
89
In news:40881ee9$0$213$edfadb0f@dread12.news.tele.dk,
:: meddelelse news:c694o7$932ma$1@ID-230693.news.uni-berlin.de...
::: I have now noticed that my monitor now flickers on one side of the
::: screen. Is there anyway to test it to see if the monitor is faulty?
:: Well, you could try another monitor.
:: Did you try to blow the dust out?
:: /Henrik
Best I could. Its a TFT monitor and does not have much space for dust to
get in or out. Problem still persists.
G
Guest
Guest
On Thu, 22 Apr 2004 22:20:17 +0100, "KerplunKuK"
>:: /Henrik
Hey you could try aida32 there is some test to do with that... check
it out...
in the section plugin / aida32 monitor diagnostics
Hope it can do some thing for you ....
have a beer, hup...
G
Guest
Guest
news:c69d0e$9ab47$1@ID-230693.news.uni-berlin.de...
Hehe..
Well, there shouldn't be much high voltage in a TFT monitor :)
That's only in CRT's.. (And that's what I have :) )
Ok, then:
I would try to locate the clicking sound exactly: Is it from the monitor,
from the card, or somewhere else? That could tell where to look.
I would also try the cable, try to reseat it, and perhaps twist it a bit at
both ends to see if there's a loose connection.
Perhaps I would even try to reseat the card on the MB, to see if it was
loose in its socket.
I would also try another monitor, and/or try the monitor on another PC.
I still mostly suspect the monitor, but it _could_ always be something else.
Problems are tricky to find the source of, sometimes :)
(If you read my post from several days ago, you will see that I had a card
act like it was bad, because a fan was connected on its powercord..)
Henrik
kerplunkuk
89
In news:408846bf$0$204$edfadb0f@dread12.news.tele.dk,
:: meddelelse news:c69d0e$9ab47$1@ID-230693.news.uni-berlin.de...
:::::: I have now noticed that my monitor now flickers on one side of
:::::: the screen. Is there anyway to test it to see if the monitor is
:::::: faulty?
::::: Well, you could try another monitor.
::::: Did you try to blow the dust out?
::: Best I could. Its a TFT monitor and does not have much space for
::: dust to get in or out. Problem still persists.
:: Hehe..
:: Well, there shouldn't be much high voltage in a TFT monitor :)
:: That's only in CRT's.. (And that's what I have :) )
:: Ok, then:
:: I would try to locate the clicking sound exactly: Is it from the
:: monitor, from the card, or somewhere else? That could tell where to
:: look.
:: I would also try the cable, try to reseat it, and perhaps twist it a
:: bit at both ends to see if there's a loose connection.
:: Perhaps I would even try to reseat the card on the MB, to see if it
:: was loose in its socket.
:: I would also try another monitor, and/or try the monitor on another
:: PC.
:: I still mostly suspect the monitor, but it _could_ always be
:: something else. Problems are tricky to find the source of, sometimes
:: (If you read my post from several days ago, you will see that I had
:: a card act like it was bad, because a fan was connected on its
:: powercord..)
:: Henrik
So as long as the particular cord from the power pack only connects to the
video card, it should not have a power issue? Thats the way I understand
it. i shall open up, reseat, check cables and listen for noises. Will
report again tomorrow. Thanks for your help.
kerplunkuk
89
"DreamMaker" <onesuponatime@yahoo.ca> wrote in message
news:07rg809lsk3tm3ig0i0qlv77sotnkmrvpp@4ax.com...
> >:: /Henrik
> it out...
> have a beer, hup...
Nope, that ran fine. Clicking seems less, but the monitor picture is now
getting worse, so guess initial diagnosis of monitor voltage may have been
spot on.
