E ElToroXCI Honorable Jun 13, 2015 59 1 10,535 Feb 23, 2016 #1 Hello. so basically the question is if frames will get lower if i combine a 16x with a 8x pcie socket The gpus are 980ti and the cpu is a 4820k
Solution WildCard999 Feb 23, 2016 There's no noticeable difference between a x16 and x8 slot so no you won't get less performance if you use a x8 slot over an x16 slot or combined.
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Feb 23, 2016 Solution #2 There's no noticeable difference between a x16 and x8 slot so no you won't get less performance if you use a x8 slot over an x16 slot or combined. Upvote 0 Downvote Solution
I iamacow Admirable Feb 11, 2015 2,090 2 6,460 Feb 23, 2016 #3 The bandwidth of PCIE 2.0 16x isn't fully used yet, which is 8X PCIE 3.0. So no you won't see a difference. Upvote 0 Downvote
